BLACK RX1
i was wondering what top speed roughly i should get on my sled.
03 rx1 mtn just broke in 900kms
05 clutch update
updated float bowls
132.5 mains
the rest is stock
oil and filter just changed 0 oil used in the 900kms
so far on a couple of lake runs in about 3to4 inches of snow with a large
base i'm not seeing more then about 105/110 km/h apox 65mph at 10200/10400 rpm
racing my son's 800 summit and my friend's rx1 mtn set up same as mine
and a700 mtn max with pipes and clutching
alt that we were riding was about 4500/5500 feet
05 clutch update
updated float bowls
132.5 mains
the rest is stock
GUKROKIT
Had to gear up to see triple digits on mine.Now goes 109mph on the speedo consistently.If you are running on flat land at sea level you will want to gear up stock gears are for 8-10000 feet.I was seeing 89-93mph before the gear change(on the speedo)well worth the work!
rx1mtn
I have seen 117 on the speed-o in what I call perfect conditions. 108-110 is the most commen for me though. 117 was at 11500 RPM
Buckeye
- Lakes Region, NH
The rev limiter kicks in at 11,400 on mine. When that happens there is no power.
snowman
The best i've seen on my 03' blue RX-1m was 107mph on good conditions, everything was stock.
