Torque spec for speedometer pickup cog
AttakMax
Corner Brook, NL, Canada
Canada
2013 Nytro XTX 1.75 Supercharged
2007 Attak 144" ZX2
2002 SRX 136" Mono
Does anyone have the torque spec for the bolt that fastens the speedometer pickup cog to the end of the track drive shaft. This is located on the clutch side. This belongs to a 2007 Attak. Thanks.
I don't know the torque spec but it's not too critical. I've had mine off dozens of times and I just tighten it back up with a 3/8" ratchet to the point it's tight. It's hard to describe what "tight" means but I crank on it pretty good. I know that's a pretty non-technical description for you but there's no load on the cog and it just needs to be tight enough so it doesn't spin out. I've never put any loctite on mine and never had any issues with it coming loose.
