#$%&* #$%&* TORS !! NO More!
Freak
Spanish Fork, UT
I have been fighting this stpid F'ing sensor for a month now. Finally it got me good. Sled died right on the peak of a large hill. She came down backwards, rolled once and stuck. I was Lucky as He11! So I decided its time to disable it. Cant beleive how easy it was. Unplugged the two m/f plugs by the mag side carb and plugged them into each other. TORS disabled and sled runs flawless now. I will put on a tether now to be safe. A safety switch is pretty much worthless when it cause a dangerous situation in itself!
I had a similar problem with my vector. After a couple close calls at the top of some cornices I decided to override the d%$* thing. You know the d%$* thing doesn't work very well when Yamaha tells you how to override it. My brother borrowed my other brothers RX1 and unfortunately he got bit and the sled rolled 20 times before it came to rest. Fortunately he didn't get hurt. Believe it or not the sled ended up with minor damage also.
You sure can man! Use the search button on the top of the page and type in what you want to know about! ;)!
Skydog
It hasn't given me a problem on my vector but on my kid's MM7 it is a real pain. I think he should disconnect it before it wrecks his sled.
