SIMMER
Frostbite
I asked Barry Holtzman about the item I have attached from SLP. He said he wouldn't try it. But I like the idea of the ones you show here. The thing I like is that you can close them if the results aren't what they like. What I would like is a reciped of where and how far open each one should be to achieve best results. Powder Blue
http://www.startinglineproducts.com/Yam ... write.html
Intake & Fuel Systems: Flow-Riteâ„¢ Intake Kit
Need more air?
Eliminate air intake restrictions by installing the Flow-Rite in the dash or intake tract for more air box feed. The Flow-Rite is supplied with a powder pre-filter that repels snow and water, yet passes air right through. A must modified sleds. Sold per each.
Part #14-189 and 14-194: SLP part numbers 14-189 and 14-194 are made using a rubber flange to attach the Flow-Riteâ„¢ to the surface that it is being installed in. This rubber flange conforms itself to a wide variety of contoured, shaped, and textured surfaces for a universal mounting system.
Part #14-197: SLP part number 14-197 is designed for ease of installation on flat or nearly flat surfaces. It requires a 2 1/2" size hole saw which is readily available from any hardware store. Installation is a snap: hole saw the hole, debur the edges, clean hole saw shavings and snap Flow-Riteâ„¢ into place.
Installation
14-189
14-194
14-197 INSIDE
DIAMETER OUTSIDE
DIAMETER REQUIRED
HOLE SIZE PART # PRICE
14-194 2" 2 11/16" 2 7/16" $17.95
14-197 2" 2 3/4" 2 1/2" $17.95
14-189 2 1/2" 3 5/8" 3 1/8" $17.95
Home Contact Sales
Back To Top
Need more air?
Installation
14-189
14-194
14-197 INSIDE
DIAMETER OUTSIDE
DIAMETER REQUIRED
Home Contact Sales
Back To Top
