TPS signal wire ???
mysledblows
Central MN
Sidewinder, mcx phazer, phazer, apex
LOCATION
Jenkins, MN
Anyone happen to know which wire is the TPS signal wire on an 06 apex? 3 wires on the plug. I'm told one is ground, one is for power when starting, and the other is the signal when running. That's the one I need.
By looking at the wiring dia the
B/L wire is the power to all the engine sensors, it comes from the AC magneto. Gray wire comes from the ECU to the magneto B/L wire goes from there to all the engine sensors and then to the ECU.
L looks to be the ground wire. All of the engine sensors are connected to it and then to the ECU
Y appears to be the signal wire back to the ECU. Each of the engine sensors has a different colour wire back to the ECU.
That's the way I see it anyway.
That's how I was seeing it as well. Appears that is correct. Thanks!
Clock at 2:05
When is one of you genius's going to solve the clock problem. Mine started going up and down.
