the track size is a nominal size, the real length is the product of pitch x number of pitches.
57 x 2.52 = 143.64 inches
the pitch is measured at the center of the belt (where the fibers are) and thus the inside will be slightly smaller.
But, tracks start on the tight side and stretch over time - so measurements are approximate at best anyway.
A 141 (2.52) is only 1 pitch shorter than a 144 - You can simply count the number of pitches to see which one you have, but I highly doubt that is a 141. I believe you have a 144 that is just on the tight side. And yes they take a while to stretch.
