ATV PRO #11
- Jan 22, 2011
- Garson, MB, CANADA
- 2014 Yamaha Phazer XTX
Just curious guys, i've been ignoring the icing issues i've been having on the back of the sled and my left foot icing up pretty bad.
How many have the front hold blocked as well as the rear??
I'm sure 99.9% have the rear done but is the front one necessary to block as well? Was talking to my dealer and they said to leave it open.
I noticed on this post, without many negative replies, that both holes were blocked: http://www.ty4stroke.com/viewtopic.php? ... el&start=0
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 18 Sidewinder (Wifes)
12 Nytro XTX (mine)
09Apex GT (?)
02 Viper (grass dragger)
Only rear blocked off with no problems.
Lashcat
I blocked mine off. I puled the plastic off the back and put heat tape on it. The only machine that I have seen with a heat issue was cause by saddlebags. They prevent air flow across the plastic to keep it cool.
MikeWalters
- Feb 21, 2010
- Saskatchewan
- 2007 Phazer
yamahinn03 said:Only rear blocked off with no problems.
x2 for me. I might block off front if I ever have sled that much taken apart.
Basically not going to bother unless its already in pieces
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Block off both and no wet left foot, no ice build up in tunnel, no problems whats so ever. Some effort required but the perfect opportunity to go bigger ie: 136" freeride. The wife swears by it. These sled have so much potential, it's up to the trainer..
Leno
- Jan 18, 2010
- Lindenhurst Il
- 2008 phazer 151
Only the rear for me but i did notice last year that i was having some ice build up in the front so this summer it will get blocked off.
ATV PRO #11
- Jan 22, 2011
I'll wait for a few more to chime in, but i'm thinking I'm going to block the front off.
Wet left foot does not make for a super fun ride
nobrakes
I picked up a 07 standard last rear. Im going to block off both. I usually only hit groomed trails and I had alot I mean ALOT of ice under that tunnel. So much that the track was rubbing on it!
A company right near me can make custom block offs. CTECH is the place.
www.racecabinet.com and Josh is the guy to deal with. They make Aluminum race cabinets and can hammer out any aluminum stuff you can think of.
Lite
Mine is blocked complete back, and with perforated alu in the front. Seems to work fine, for the little i have tested.
