tunnel weight savings from stock.....15 lbs maybe?
GotJuice
Klukwan,Alaska
I'm wanting to add a few things to my sled and I'm trying to decide which to do first for many reasons tunnel probably being next. Who makes a solid durable tunnel with open designed running boards and can save me some weight ? I have looked at Vannemberg, CRRacing, Timbersled and Fabcraft...I don't see any weight comparisons to stock Apex Mnt. ? I'd also like to spend around 1200.00 for the tunnel with coolers & bumper, rack is optional not necessary. ( wether the coolers run along the running boards or under tunnel it doesn't matter to me ). Doesn't have to be really fancy just functional with high ground clearance and I like the kick up in the rear....any suggestions ? All input appreciated!
Boondocker van am tunnel, they are sick. Have nice boards that exit alot of snow and ahuge kick up for clearanc ein the back, also large coolers. This would be my choice.
I like there stuff
Yeah I like thee design but wondering on the weight savings from stock to a Boondock tunnel or a CrRacing tunnel of similar design....someone has to know the weight savings ?
boondocker tunnel is a 24 lb savings if you have double bypass cooler. 26 lbs if you have the standard cooler. These weights were done with my stock tunnel in the spring at Vanamburgs shop. This is with an 07 apex mountain tunnel
Sap
THANK YOU
Sap
Thanks for the info, much appreciated! Thats what I was wondering, that's an awesome gain for the money!
