Jeff Rueth
Hey guys I’m on the road for work so I can’t check the size of the bolts everyone replaces. There is a fastenal outlet store across the road. What size and length please and how many? Thanks
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
8mm-1.25x20Hey guys I’m on the road for work so I can’t check the size of the bolts everyone replaces. There is a fastenal outlet store across the road. What size and length please and how many? Thanks
Jeff Rueth
How many?
snowdust
6How many?
Spicoli
- Dec 8, 2016
- Waterford, Ontario
- 2018 Sidewinder L-TX DX
Get 24 to have some spares, they are worth having around.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Crazy Canuk
So, I bought these bolts and washers reinstall the muffler. They dont seem to want to go in and I dont want to force things and screw up the turbo. The stock bolts go in without issue. I am missing something?
grubf
- Dec 9, 2008
Did they sell you the wrong bolts?So, I bought these bolts and washers reinstall the muffler. They dont seem to want to go in and I dont want to force things and screw up the turbo. The stock bolts go in without issue. I am missing something?
Crazy Canuk
No, they are packs of 2. I tried a couple of different packages. Maybe I should chase with a tap? Not sure.
grubf
- Dec 9, 2008
If the stock ones go in with no issues the threads should be fine. Do the new ones have a little dab of locktight or some other stuff on the threads?
Crazy Canuk
That's what I thought as well (they should go right in). There is nothing in them. I wanted to run em in before I put anti sieze on them.
stohlem
- Jan 11, 2015
- 2017 Sidewinder LTX LE, 2014 Apex XTX
- Illinois
FYI, I purchased SS bolts slightly longer and had to cut them to length. What I found is the 2 bottom flange holes don't go all the way through. I checked by inserting small screwdriver in holes. It would suck to bottom out and snap bolts. My 2 bottom bolts are now slightly shorter.
Crazy Canuk
Thanks. This is really any hole. Maybe a bad batch of bolts?? May try to buy some more tomorrow.
Turboflash
- Mar 18, 2019
- Southern MN
I'd be very suspect the ones you got were mismarked or just plain wrong. If you don't have a die with the same thread, often hardware stores have thread checkers where they are selling their bolts and nuts. Take them there and see if they are the right thread. Make sure to bring an old one to compare to. Don't tell me, they were made in China. LOL
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
X2..
Try n mesh one of the old bolt to a new one, hold the bolts with the heads opposite to each other and see how the threads fit together, when you put the two threads together they should fit together perfectly. At least that will tell you if the pitch is right or not.
Turboflash way is the best way..
