xtxmcx270
Hello, any good clutching starting points for a Nytro XTX with MCX 270 turbo.
tfrick821
I want to know where you plan to ride at 12000 feet with a 3/4" track, especially when you weigh over 350 pounds
Just kidding that was all sarcasm.
Sorry dont know jack about turbo clutching but couldn't resist.
TTT for ya
TTT for ya
xtxmcx270
tfrick821 said:I want to know where you plan to ride at 12000 feet with a 3/4" track, especially when you weigh over 350 pounds
TTT for ya
Mohahaha
Turk
Tech Advisor
I am partial to the 20/50 supertorquer 2 speeds but the supertips will work too. It,s just that the 2 speeds are so easy to tune & dial in. Do you have a preference on what weight you want to use?
xtxmcx270
No ,im open to all suggestions.
I have heard that Nytros are belt eaters when they are turboed.
Should a more shallow helix be good to help that problem ?
What about mcx own weights ,are the any good ?
Sorry but what is: 20/50 supertorquer ?
/thanks.
/thanks.
Turk
Tech Advisor
Eating belts is usually a result of bad clutching.
Using too steep a helix without enuff secondary pretension is the cause of that.
20/50 is a weight made bt supertorquer.
Check out their website.
http://www.supertorquer.com/
I don,t know anything about the mcx express weight as i have never used em. I am sure tho they have some good set ups.
xtxmcx270
What is you other Nytro Turbos running for setup ?
jimmyhighway
- Feb 6, 2006
- Northwestern Ontario
- 13 Skidoo Freeride 137
11 Yamaha Nypex MCX
clutching
I have been running the 60g supertips for two seasons, which seems to be a good starting point for tuning the MCX. I run the 230 kit.
ttt
xtxmcx270
Re: clutching
What helix are you using in the secondary - and what spring ?
jimmyhighway said:I have been running the 60g supertips for two seasons, which seems to be a good starting point for tuning the MCX. I run the 230 kit.
jimmyhighway
- Feb 6, 2006
11 Yamaha Nypex MCX
I run the stock RTX 43, and the yam white sec spring. Y-W-Y in the primary.
xtxmcx270
What is your average belt life (with turbo).
Im trying to find out a good combo which is nice to my belt.
(dont want to end up like the skidoo boys).
T-Nytro
Here is what I run on my MCX (270 kit) Nytro with a 162 2.5. These are mountain setups though.
8BU-00 (48.7 Grams) weights fully loaded 9 grams.
B W B primary spring
14.5 Rollers
45 degree helix
Pink secondary wound 70 degrees.
OR
47 degree helix with cat purple.
14.5 Rollers
45 degree helix
OR
TBird
- Dec 25, 2004
- North of Sweden
- Sweden
- Yamaha Viper and Yamaha Nypex
There are soooo many factors for a clutch setup, there are no setup thats best on everything!
For scandinavian driving, both on and off trail, where off trail is boondocking/treeriding i would suggest 14.5mm rollers, blue/wh/blue and supertips or heavyhitters.
45° helix with Yamaha white @ 60°
or if you boondock alot an cat purple @ 70°.
This works pretty good, but i've seen Nytro MTX's blowing belts regardless off tuning and cooling if boondocking a really long time without letting the clutches cool down.
