Ulmer kit
superb
Ottawa, Ontario
Canada
2015 Viper turbo, 2013 Apex, 2012 Vector LTX, 2010 Vector LTX
Can anyone tell me the colour of the primary and secondary springs used in the ulmer kit? Is the primary spring pink/ pink/pink. Thank- you
What kit do you have? Are you boosted,and run his stage 2 kit?
Mine has one pink mark on it(primary spring)
All stock sidewinder.
The reason I asked if you were boosted beyond stock,is my clutch kit from allen is stage 2 kit,helix secondary spring,STM primary weights and pink dot on primary spring,and red secondary spring,with tang in different pos. than a standard Yamaha secondary spring,and straight 38 degree STM helix.
just to know i have a 38 also what is the washer placement on the arm?
Not sure I understand the question.Washer placement? What arm? Were you not speaking of the helix 38 degree you have? Did you mean tang location on helix,for twist?
no on your supertips weight were are the weight how many washer on heel mid and tip?
This placement is for the stage 2 clutch kit to go along for the stage 4 tune,so tip one tungsten on each side for 14 grms,and mid empty,and one washer on each side at heel,total weight 80.9 gram.Mine is 3"sandale ans CAI at 14.7lbs or his max boost kit of 16lbs,for the 14 gram in tip.
Anyone running Ulmer clutch kit with TD power tail?
Yup stage 2, ran stage 1 last year, haven't tried the stage 2 yet. All I know is that he uses an aggressive helix. Not sure on the angles.
I'll be running a TD powertrail flash with SQ exhaust and CAI and using Ulmers clutching. Now the Pt flash is 14.7 lbs so looking at Allen's chart I'll add 2 washers to the tip compared to stock and go from there. What's the ideal rpm for the powertrail flash? Allen's paperwork lists stage 3 and 4 at 9200 to 9400 or something like that so not sure about target rpms vs Allen's setups vs flashes Ulmer racing sells. I'm also gonna be running a 33/35 TP helix with their orange spring. Also have a Dalton black/blue primary to try. Not the most knowledgeable about clutching but I'm guessing with the dalton spring I'll have to start off with a little more heel weight than the pink spring that's in the Ulmers kit.
