RSVECTORFREAK
- Oct 28, 2004
- Chassell Michigan
- 2005 RS Vector ER
IAVECTORGT said:Excellent, thank-you!! One last question, are the bolts that go through the sleeves for the weights supposed to be torqued to a certain spec or just tightened/snug?Srxspec said:Guys, he has a Vector, not an Apex. Your top rpm will be in the 8400 to 8600 rpm range. Yes, use your original secondary spring and follow the setup sheet for spring position of 3-3. Your engagement at 3600 rpm is correct, yes.
Tight enough so the weights move freely but not too tight that they bind up! Should be free swinging!
