Theicor
Anyone out there know of anyone that makes an under tunnel exhaust setup for an Apex besides Excell? I am just looking to see if there are any more options out there before I pull the trigger, otherwise, I'll be going with the Excell. Thanks!
Boondocker_X
Call Lincoln County Customs in WY. They have a kit that used to be called TJ's that they sell.
yamahaboy_15
no build one not that hard nothin wrong with buying it but it cost so damn much 1000 from lcc an excell is somewhere around 500ish go to napa or shucks get a car resignator bout a foot long an weld ur two into one off ur stock pipe then make a bracket a end pipe and ur done for about $55
powder muncher
totaly easy --cut the exhaust outlets of and weld some pipes left and right side of the stock muffler facing forward under the tunnel.
If you wish you can gut the muffler loose about 5 pounds and have all the room out back and on the side of the tunnel.
Cost= a couple hours with the welder .
just did one
cheers..........
just did one
cheers..........
