matt@mpi
- Feb 10, 2011
Stage 1 upgrade kit for MPI Yamaha 180 kit
This kit converts your Yamaha 180 kit into a true Stage 1 kit. Includes everything you need to make the upgrade. By upgrading your 180 to a stage 1 you can run more boost over the base kit. This kit is an easy bolt on to the stock 180 kit.
TURBO
MTN-1100 $1095.00
The Turbo upgrade includes:
New high flow intercooler
Dual sided waste gate
Stiffer Blow off valve spring
New aluminum charge tube
All the necessary hoses and hardware
Re-flash of your stock GEMS controller
SUPERCHARGER
MSN-1100 $1195.00
The Supercharger upgrade includes:
New pulleys for high boost
Cold air kit
TURBO
MTN-1100 $1095.00
SUPERCHARGER
MSN-1100 $1195.00
Cold air kit
double a ron
Does this reflash solve the stutter / stumble issue identified in TSB-504?
matt@mpi
- Feb 10, 2011
double a ron said:Does this reflash solve the stutter / stumble issue identified in TSB-504?
Yes it will. This re flash will open up more range in your fuel controller.
double a ron
Good to hear. How much for just a re-flash so we can get our base kits to work like they should?
matt@mpi
- Feb 10, 2011
double a ron said:Good to hear. How much for just a re-flash so we can get our base kits to work like they should?
If you cover the shipping back and forth we'll do it for free. Call and get a RA # from us.
AKNYTRO
- Apr 1, 2010
how much more boost can we run?
matt@mpi
- Feb 10, 2011
AKNYTRO said:how much more boost can we run?
It depends on how much you’re running now. If you’re running 5-6psi I think you could run 1-2psi. That might not sound like a lot but its 10-20 more HP. If you combine this intercooler upgrade along with our ECU re-flash you could run 10psi (220hp) on pump gas. The ECU re-flash pulls a little timing out in higher RPM. It’s like doing a head shim without opening up your motor and without the ill effects that the shim has on your bottom end performance.
