snowslammer
i found a killer deal on a used 2012 apex with 800 miles it is has the mono shock suspention i was wondering what i should look for when i look into this sled or any issues with these models i need to know about, looks brand new any input greatly appreciated
Daranello
Suspended
snowslammer said:i found a killer deal on a used 2012 apex with 800 miles it is has the mono shock suspention i was wondering what i should look for when i look into this sled or any issues with these models i need to know about, looks brand new any input greatly appreciated
I love mine..no issues....curious whats the used market like...whats a killer deal??
80h4thephaze
Buyer beware of the lack of clearance on the new monoshock apex. Very little space. Not sure how some people dealt with that?
snowslammer
lack of clearance? 7500.00 is what i can get it for i think its a good deal?
Unless it's been crashed it is a heck of a good deal! If you don't want it let me know I'll come and take a look!
80h4thephaze
Ya good deal for sure. I would just check with other members to see what they are doing on the idea of studs as the ones I have worked on in the past did not have much leeway for clearance. My XTX has more clearance than the monoshock skid, and I ran into studs hitting exhaust, so I dropped the protectors and riveted an aluminum plate to the top of the protectors. No issues since!
80h4thephaze
To clarify, the plate only covered the exup.
02ViperMody44
- Jan 26, 2009
- Utica, NY
2013 Yamaha XTX
- Old Forge, NY
- YAHOO
- ramody44@yahoo.com
For the studding issues, you may want to look at the Hauck kit, a rivet on hyfax attachment to the stock tunnel protectors:
http://www.hauckpowersportsinc.com/page ... duct/60284
On my XTX there is noticeably more clearance than the standards that I looked at. Also, I reinforced the brackets that hold the tunnel protectors to the sled, to prevent them from flexing. Used rubber stoppers.`
Daranello
Suspended
I.ve got 1,200km on my Apex 128 with an ICE Attack XT with no issues
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
Buy it! Or let us know where it's at and one of us will.
Agman 57
- Dec 28, 2006
- Fostoria, Ohio
- 2018 Apex XTX LE, 50th Ann.
2018 Sidewinder LTX LE, 50th Ann.
2017 Sidewinder BTX LE
1992 V-Max 4 (Modded)
2002 ZR 120 G-daughter's
I think I looked at this sled the other day. Looked good. sounds like a killer deal. Don't see how you could go wrong!
snowslammer
ok looking at it wensday will let you guys know thanks, if you put a plate over the exup do you guys see that causing any issues?
kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
I have a 12 128". All I did was put a 1/4" thick washer under the protector bracket's. Just need to drop the rear of the skid out, you will need to take the three screw's out of the dial adjuster and lay it on the skid out of the way aswell. Not even a nick so far. This is Yamaha's recommendation!
You will need some blue lock tight because the self locking nut's will no longer go on far enough to lock.
ersky
- Feb 6, 2009
- ont canada
- 06 apex gt s/c (sold) 04 rx warrior apex converted 2 stage bender turbo. 12 venture gt (getting old)converted to 11 apex
building a custom apex
i put the plastic on my 06 apex and 04 warrior 6 years ago i bet before hauck thought of it
ersky
- Feb 6, 2009
- ont canada
on the tunnel protectors
