bigcountry
looking at putting some drop brackets on the back of my 04 warrior, mainly for stud clearance. can you just bolt the drop brackets on without changing any other mounting holes?? i was under the impression that they could just be bolted on but i'm not so sure anymore. thanks in advance guys
RXMax
That is a 3 mount rear suspension. In order to keep it working correctly you have to drop the middle hole by the same amount. They had those adjustments on the 141 suspension on the MM and when you dropped it down it added ski pressure and made it harder to get up on the snow FWIW.
