mmunsell@smtool.com
- Nov 22, 2006
Got a Vector, 2006, set the jetting for high altitude but need more rpms. How many tooth top gear should I drop to help this out? Or any other ideas would be appreciated. Thanks
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
What model Vec. do you have. The standard gearing is 22 38. Not sure about the mountain. I run 22 40 in my 06 Nytro. Stock is 21 40. That is good and low.
mmunsell@smtool.com
- Nov 22, 2006
It's just the short track Vector....not the mountain.
mmunsell@smtool.com
- Nov 22, 2006
WOW.....need some help. Again this is a VectorRS with high altitude jetting. Need more rpms. HELP!
radianguy
- Jan 1, 2007
Gain RPM with lighter weights in the primary clutch.
