Vector GT Suspension set-up
TrueBlue
Franklin Park, IL
Trying to set rear suspension up for my weight 240lbs. The problem is that on 1ft. moguls going slow or a little faster I can hear the shock banging against the stop.Not sure if it is hitting the bottom stop of the shock or the top stop of the shock (rebound).It does make a hell of a bagging noise. I have tried the hardest setting on rear coil shock & adjusted the RA dial on the tunnel to the hard position and then to the soft position it still bangs. I then set the rear coil shock to a softer position No. 4 and set the Ra dial to hard position and then to soft position it still bangs.
What am I doing wrong?
Any help would be helpful.
Thank's :o|
I don't have the gt I have the er, and going slow over bumbs like that all I hear is limiter strap banging as the front of the suspension drops back down.
Mine sounds more like a mechanical stop, kinda of a "knock" when it rebounds. Gotta be a way to adjust rebound dampening on this puppy!
