yooper1
I installed a new speedo for better visibility and clutch tuning for me supercharged Nytro. Big thanks Superman!
yooper1
yamaha1973
- Nov 27, 2011
- St. Peter Minnesota
- 2014 Viper XTX SE
looks great!
LSXM3
How much was involved in the swap?
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
Your going to love it, best upgrade I have done. Only thing involved with swap is mounting the gauge since the bolt patterns are different. If you want the clock to work you need to run a constant 12v wire to the gauge. Lots of how too's floating around, including mine.
yooper1
It was easy to do, it's all about how nice do you was it to look. I was thinking that the unit is plug and play, could you use a Vector pig tail and swap those too? It's only 8 inches and should plug right in. Maybe the needed jumped wire is there already?
Beenba
- Feb 16, 2011
- 2009 Nytro XTX
The nytro plug installs fine into the back of the vector gauge.
It is just missing one pin (the +12v one for the clock)
I used a pin from an old honda car I had laying around but since you have the plug from the vector speedo, just de-pin one of the wires, and reuse it into your nytro.
Compare the two plugs, to see where the extra wire goes.
