Windsorsledder
I have a 2006 Vector ER 121 inch and the track is shot. Just wondering if I can replace the 1 1/4 ripsaw track witn a 1 1/2. Thanks Mike
yamaman98
Mike I extended my 05 vector 121 to a 136 x 1.5 and have had no problems. I wouldn't recomend using studs.
Windsorsledder
Right now I have 96 studs 1.325 down the middle. You do not think I would be able to stud it if I got a 1 1/2 track
yamaman98
If you go to smaller drivers you could run studs, but I wouldn't recomend doing so with stock drivers, very little clearance up front.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Get an Ice Ripper XT track with embedded carbide tips...works almost as well as a 96 studded track...and no wrenching and maintenance required.
Windsorsledder
Thanks for the replies. I decided to buy a 1 1/4 ripsaw which is what was on it. Because my studs were still in great shape just I had 5 pull thrus. I am Canadian and ended up going to the Novi show which is near Detroit Mi and I got the track for $350 which I thought was a great deal.
