I ended up with a barrel of each of these fuels. The motor octane difference is VP111 is 107 octane, and C12 is 108 octane.
Besides the obvious motor octane difference of 1 point, can I treat these fuels the same when i'm blending it with pump for my T-Nytro?
Based on the calculator I'm planning to do a 50-50 blend for 18 lbs boost at 6000 feet with 9.5 to 1 compression and powderlites recommended timing changes. That's what I ran on my Apex last year with similar changes without any issue
I can not see why not at 50/50 mix it should only bring the octain down 1/2 point.
Look at the weight of the barrles marked on the tag I think the 111 is heaver, on a carb system it could make a difference.
HURRICANE
Look at the specific gravity of the two fuels.Thats important for the burn rate of the fuel.There may be a conciderable diffrence in the specific gravity
mbarryracing
- Aug 31, 2007
- Springville NY
- 2006 Yamaha Attak Turbo
2015 SR Viper RTX-DX
1996 Vmax 600XT
HURRICANE said:Look at the specific gravity of the two fuels.Thats important for the burn rate of the fuel.There may be a conciderable diffrence in the specific gravity
X2
Affects AFR's as well.
Specific Gravity: .720-.735 @ 60° F for VP111
Specific Gravity: .717 at 60° F for C12
Is that close?
HURRICANE
that's close enough
BigDog05
If you determine that you need around 102 octane for around 12 psi of boost, what specific gravity number are you looking for?
Example: VP red is 105 motor octane, with a specific gravity of .730-.745.
Sunoco 110 racing is 105 motor octane, with a specific gravity of .728.
Both are readily available and approx. the same price.
Do you want the highest specific gravity, or do you want to stay above a certain specific gravity like .715 for example? Thanks
