wear grooves on clutchs
snoway
SE.WI.
Website
www.vrbo.com
Never had this happen on any of my other yammies, but the 08 vector has a groove worn in both clutchs . I would call it fairly deep. I don't drive this one different than my other sleds, and I vary my speed all the time.
There actually are a series of rings or grooves, but the minor ones sanded out of the primary with 120 and then 180 grit sanding while running.But the main one is still visible.
I have run yamaha belts since new.
Anyone else seeing this ?
Are u gonna post on all picks here ?
LB is kanda right... (on the other one) the 8DN got the disadvantage of its advantage but.... he got no idea how bad it is on the 3 holer.... he have 4.....
LB.... good to see ya back... must have been summer sleepin..
I maintain my clutch faces on the lathe, all other gizmos is futile, you'll get assimilated.
have good season's rides
