what are your best gems settings on 14 rtx 190 mpi kit
Gems or PCV?
  • Total voters
    3
nytro rtx se
Cambridge-Bay,Nunavut,Canada.
Canada
09 fx nytro rtx se old sled
14 Sr. viper rtx mpi190 old sled
17 sidewinder 137 xtx 300 hurricane
Hey guys, Looking for advice on best possible set up on the gems with great results? Any of you are satisfied with the gems or is PCV the way to go? Almost complete install on mpi 190 and looking for your advice from ppl with experience. Allen Ulmer did clutching on primary and secondary which both are machined n set up for 8dn, have 21/41 and this is on a 14 rtx @ sealevel. I just msg Allen so waiting for response. Any advice will be greatly appreciated Cheers:)
I just picked up my kit and I think I may be going with the pcv pti for me because then I can get Allens maps that he has spent time tuning. Also if I plan to up the boost I'll already be one step ahead for better control
Best part about the pti unit is there's no need to adjust, as the sled builds more boost the pti unto automatically corrects and adds more fuel when needed.
That's what I like about it after I did some research up on it it's the safest way to go. I plan on going with the stage 1 kit but add pcv pti so I have spot on fueling all the time and no worries about going lean if over boost may happen
Have you done much adjusting with the gems?
have yet to use in i just got my turbo i had a similar one on my old f7 a pure lodgic controler i like the pcv more because you can change it on your computer and the fact the pti version will change the fueling based on boost and i can but my ignition module on it if i like
Got ya. I don't disagree. BUT I am not much of a tuner and don't plan on starting. I've ajusted my gems twice. Much better numbers now. Sled pulls very hard but starts and idles like my apex used too. It was very rich from the dealer.
IMO the gems is nice for set and forget. i got 2400 miles on the sled this year and once I got the gems setup it never changed.
One complaint is fuel mileage but from what I read the pcv does not get much better ( you pay to play).
I was thinking that too my plan is to set it an leave it I like that the pcv can be tuned better = greater mpg but if you got yours running great then I may just stay with the gems and save the money
