TrailxRider
Does it matter what fogging oil to use? I've never fogged an engine and read up on here and it seams simple. I just ordered a case of amsoil so should I stick to amsoil fogging oil as well or can I use another brand?
What other fogging oils are good that I could possible find at a local retailer such as Napa, Advance Autoparts, Walmart, Sears, etc.
RobX-1
- Coldwater, OH
I know you can get Napa brand fogging oil (it's what I use) but I have also seen fogging oil at Advance and Autoparts.
SnoWarrior
- Jan 13, 2005
- Long Island, NY
- 2024 Sidewinder L-TX LE
Pretty much any brand fogging oil. I use Marvel Mystery Oil, both on my outboards and sleds, never had any problems. I put some in a spray bottle and just spray it in the carbs.
hondo
I use "Seafoam, Deep Creep".
Its a multi-use product, and is labeled for fogging. It works good.
I also pull the plugs, and spray it into each cylinder. With the plugs out, turn the primary clutch a few times to coat the cylinder walls.
Hope this helps!
Hope this helps!
