What gears produce what psi of boost?
Apex Man
Lagrange, Ohio
I'm getting an MPI 10 psi SC kit for my Apex. What drive and driven pulleys will that come with? What ratio do I need to get only 7 psi? Gear ratio for psi calculation doesn't seem to be linear. I will spin 10,500 max. I really only need 7 psi but I'm getting a good deal on a 10 psi kit. Just need to know what I have to change for various boost levels. I can get the taper-lock pulleys locally and I'd like to get everything I need to make the change.
Thanks,
Ralph
If you are getting the kit with pulley set to make 10 psi those pulleys you are getting can be reversed from top to bottom to make 7 psi.
