Tom-RX1
What degree is the clutch on the warrior stock with the white spring .
Tom-RX1
Tom-RX1
Straightliner
- Aug 14, 2003
Tom-RX1, When new you are set at 60% is 3 and 3 setting. (Later)
Tom-RX1
Thankyou straitliner
Tom-RX1
Tom-RX1
RXONE
Reference
Tom hear is somthing to remember. setting #3 on the spring bottom then #3 setting on the helix. Then take the 2 settings and add them together 3+3=6 then multiply 6 x 10 gives you 60 degree twist. Another example.
bottom (secondary) # is 3 (helix) set at 6. 6+3=9 X 10 = 90 degree twist. Got it? Hope this helps.
Tom-RX1
Thanks Rxone . I have a white spring and run the shorty and was not sure where the warrior was set at stock . need that as a starting point .
Tom-RX1
Tom-RX1
