craigjschr
I looked in the manual and i tried doing like they say and its just not rite today when i moved it from the garage to clean it out it was going back and then slipped out any tricks to this also which mark do i go to on the dip stick to check fluid.
thanks
craig
thanks
craig
You have to adjust the linkages that connect the handle to the chaincase. One is vertical and one is horizontal. You adjust the horizontal to 27mm between the locknuts and then adjust the vertical so there is no tension on the linkage in either direction. It is in the Service Manual Chapter 4 Page 23. I found it easiest to get the track in the air and test it afterwards. Testing is done with the vertical linkage after you set the horizontal to 27mm. You can feel and hear it going into reverse properly and not so good.
Check also the bolt that hold the linkage to the chaincase is tighten. If the linkage is loose you will not be able to adjust it correctly.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
This should help, http://www.totallyamaha.com/snowmobiles ... egrind.pdf
It is located in here http://www.totallyamaha.com/snowmobiles ... Index.html
attakred06
make shure also that your chain is not to tight,same problem,,different issue...has happen to me...bye
Budweiser
I feel your pain. Mine would grind once in a while going into reverse. I tried multiple time to adjust the way the manual says but its tough to do because its hard to get to the linkages. So I took the brake caliper off and rode it in the back yard. I kept making slight adjustments and riding it in reverse, forward, reverse. Since doing it this way I have not had it grind once. Now I don't mess with the adjustable linkages...that was my first mistake!
