XTX Tunnel Extension on RTX
furg69
st.anthony newfoundland
Does anyone know if the stock XTX Tunnel Extension Fits directly onto the RTX Chassis ? Getting my things together for the conversion, just wondering if i can use the OEM xtx one or maybe go with CR RACING, HARTMAN etc.
stopdropanroll said:
Use Ulmers extension! Its tig welded on the end, much nicer then stock (tons of rivets and 3 pieces) Tracks USA uses the factory end cap and fits like poooooooo!
What! If you take your time, and use welding clamps and put it on correctly, it fits as good as factory. honestly the best looking job on an extension I've ever seen. No gaps anywhere. Mine has a few extra rivets, since I put the tail light wire under the tunnel.
But you are kinda right, usually they look like crap, cause people do it in a hurry, or just try to squeeze it around the outside of the factory tunnel.
