ritchie
- Nov 3, 2014
- Seven Sisters Falls, Mb
- 2017 Sidewinder Ltx Le
Anybody else have problems installing the Yamaha Fourth wheel Kit? I can't seem to get the new bolts that came with the kit to go in all the way. The original bolts seem to be a finer thread.
@123
- Mar 15, 2017
- new brunswick
- sidewinder xtx
just install mine no problem it should fitAnybody else have problems installing the Yamaha Fourth wheel Kit? I can't seem to get the new bolts that came with the kit to go in all the way. The original bolts seem to be a finer thread.View attachment 133834
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
pro - x Axys switchback 800
I just received a kit with bolts that were the wrong thread pitch. I had to buy other bolts.
ritchie
- Nov 3, 2014
Did your new bolts go in about 8 turns then stop? The Bolts I got with my kit were labelled (YHC 8.8) are the new replacement bolts you got numbered the same? My original bolts say 10.9 Q
Bt04f250
- Mar 6, 2017
- IL
- 2018 sidewinder xtx 137 high Vis ordered 2012 Polaris rush pro r Le
8.8 and 10.9 is just telling you harness for a metric bolt. 8.8 is similar to a grade 5 where 10.9 would be similar to a grade 8.
ritchie
- Nov 3, 2014
Okay thanks for the info. Hopefully I can find the correct bolt.
the thread pitch is different i put a set on last month the dealer had received a tsb and the proper bolts they told me that it was the easier packaged kits that had the problem
ritchie
- Nov 3, 2014
Yeah...What a pain,I hope I did not strip out the axle shaft. I ordered the kit online and this is the last thing I expected from Yamaha.the thread pitch is different i put a set on last month the dealer had received a tsb and the proper bolts they told me that it was the easier packaged kits that had the problem
