hotrod
My Apex has 18,459 miles. Put new plugs and new belt but it did not help. HELP
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
is something causing drag in the drive train? tell us more about what happened or what led you to this place in time. did it just happen over night has it been getting worse did you do any work?
Macheater
- Feb 7, 2006
- Niles, Ohio
- 2006 Apex GT, 2002 SRX700
- Niles, Oh
Keeping the throttle always at the bar WILL have an adverse effect on mileage also!
clutches have been cleaned and inspected?
bearings all good in the wheels?
speedo bearing was repacked or replaced?
jackshaft bearing still has grease in it?
oil in chain case?
chain adjusted properly?
does track roll smoothly by hand when it is on the stand?
did your driving style change?
exh dounuts good?
this all affect fuel milage.
oil in chain case?
exh dounuts good?
hotrod
The snowmobile skid frame is in good shape. I have all new wheels from Trick toys. The only other thing I did to the secondary clutch is to put three new plastic slides. I have the spring set in the number three hole. Can anyone tell me if that is correct. The secondary clutch might not be shifting right. Thank you guys for all your help.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
3-3 is the correct factory setting for the spring. when I replaced to buttons on my secondary it took a few miles for it to "wear in" and get full shift. did you lose millage after the repairs? recheck your work and make sure it is all correct. what rpm are you getting full throttle?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
Track tension and free roll of the track is huge for these sleds. Chain tension as well. There are many variables for sure. Unless you just got a dose of bad gas. I tank with seafoam, or a bottle of ISO may be in your future.
Good luck
Good luck
engineman
- Feb 19, 2013
- Between Hastings & Redwing MN
- 2009 Apex LTX, 2010 Vector LTX GT, 1996 Indy 500 SKS
May be time for a valve clearance check? Yamaha 5 valve motors love to get tight valves.
My 2 cents....
Steve
My 2 cents....
Steve
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
do you mean 3-3 ? that would change things if you didn't pay attention to the spring setting on the other side too.The snowmobile skid frame is in good shape. I have all new wheels from Trick toys. The only other thing I did to the secondary clutch is to put three new plastic slides. I have the spring set in the number three hole. Can anyone tell me if that is correct. The secondary clutch might not be shifting right. Thank you guys for all your help.
