Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
That's when I snapped my last 8jp. Crossed a road and then got on it and snap.coil binding will not blew belt at 60mph.i always blew belt at that speed in hard accelerations after letting off throttle.I was told by yami service manager that I ride too agressive...![]()
Too aggressive..... why would you buy the 180 hp "king" to poke around the trail with.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Yesterday I went out on the lake and really used up the sled. Big starts , slowing and nailing it etc. the 8dn looked fine , belt was cool but the secondary was hot enough I couldn't hold my hand on it for long.
Lots of belt dust.
The sled pulls really hard to 100 but I need a lot more lake to see more speed.
Lots of belt dust.
78srx02
I was only blowing belts on the lake over 100mph.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
If anyone had tried a new primary spring , to avoid the binding and braking of the stock one. Can you please post what spring you used and what other changes where needed. Plus results.
Thanks.
Thanks.
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
i put thunder kit in early on, no spring specs, no issues. clutches only warm. call lonn at thunder.If anyone had tried a new primary spring , to avoid the binding and braking of the stock one. Can you please post what spring you used and what other changes where needed. Plus results.
Thanks.
MUSKOKA SIDEWINDER LTX LE
- Dec 8, 2006
- Huntsville, Ontario ,Canada
Can't go wrong with the Thunder kit I also am running it and 0 belt issues since install.
nightrunner06
- Nov 18, 2013
- madison, wi
- SideWinder LTX se
pro - x Axys switchback 800
running dn or jp?
- Dec 6, 2016
- saegertown pa
jprunning dn or jp?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
even adding glide washers to stock setup would help with the bind IMO.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
I got a TP kit too. Thought my primary bind issue was solved, but look at the following pic. Guess not.
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
Other than this, the rest seems ok.
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
Wow ya that's not good. Did you notice any rpm loss? What spring do you have in btw?I got the TP kit too. Thought my primary bind issue was solved, but look at this picture. I'm thinking not. Other than that, rest seems ok.View attachment 127208
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
That's a lot worse then my stock oneOther than this, the rest seems ok.View attachment 127208
Snowaddict
- Feb 28, 2005
- Menasha, WI
- mstahl88
It's what comes in the Thunder Products kit. Much shorter than the stock primary spring. Rpms have to be pretty close. 8900 or so on initial squeeze. Does drop off a couple hundred on prolonged wot, though.Wow ya that's not good. Did you notice any rpm loss? What spring do you have in btw?
My stock primary spring had some missing on every coil, but not that long of a gouge. Scratching my head.That's a lot worse then my stock one
That's rubbing on sides. Spring bind shows between coils where they would touch each other. Neither is a good thing though.Other than this, the rest seems ok.View attachment 127208
- 20K
