Sr Viper X-TX 141
I have a 2017 Sr Viper Xtx and it does not Wheelie like all you guys say.
yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
Here's 3 Vipers doing the impossible! It's all about set up and traction. SnoNinja sums it up best on the first page of this thread.
Sr Viper X-TX 141
How are those Vipers set up, and what are they?XTX?View attachment 150572
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
Set up and traction are key but power is also important, 2 of those are turbo and one has the Evo stage 4 flash if I'm not mistaken
yamahaguy
Ride SAFE
- Apr 20, 2014
All set up differently. 2 MTXs and 1 LTX in the picture but the XTXs like Murdered141 can do the same. Come to the next TY ride , you won't regret it
Sr Viper X-TX 141
When is that this year? And it's normally in Munising?All set up differently. 2 MTXs and 1 LTX in the picture but the XTXs like Murdered141 can do the same. Come to the next TY ride , you won't regret it
yamahaguy
Ride SAFE
- Apr 20, 2014
Yes Munising has 3 rides this season plus a few other locations. Look under rides and events section for details/dates for all
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
Plus these guys know how to ride!
- Apr 14, 2003
- Hessel, Michigan
Your stock XTX can do the same as the 3 sleds pictured above. Suspension is key.
I ride with all these guys above and was always called mr. show off....LOL
- Apr 14, 2003
- Hessel, Michigan
Set your suspension up like this (guessing you have floats front and rear)
fronts 68 psi
center spring shock, pretty much full adjusted up with stock spring
rear float 115 psi (can try 105psi and play with it off trail)
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
This should make your viper stand up!
Mike P
- Nov 18, 2015
- Berlin CT
- Sr Viper R-TX SE
- Berlin CT
yammitrip1
- Sep 28, 2017
- Rome ny
- back country sx viper, trail sx viper s
I have a rtx and I can get mine to Walk pretty good on flat land. I'm 220. It's all in set up, I use stm weights, 1.5 ripsaw 2 track, stiffer center spring which helps with the ride anyways. My sled rides like a axys chassis. Lean back, skies come up, lean forward and turn. I like being in control not my sled controlling me. Maybe I should put some videos up
Cfpdscott
- Feb 23, 2016
- Illinois
- 2016 Yamaha viper Rtx-se
How many turns do you have your center spring adjusted to?I have a rtx and I can get mine to Walk pretty good on flat land. I'm 220. It's all in set up, I use stm weights, 1.5 ripsaw 2 track, stiffer center spring which helps with the ride anyways. My sled rides like a axys chassis. Lean back, skies come up, lean forward and turn. I like being in control not my sled controlling me. Maybe I should put some videos up
yammitrip1
- Sep 28, 2017
- Rome ny
I run the cat 160-260 spring. Works great, shock doc told me about it. From no tension I'm 6 full turns. I like to party
