Yamadog
Well got to DA Hooper at 11 this morning. Unloaded all 4 sleds viper shut off and would not restart only idled 5 mins. Left it sit the tried again it fired and stumbled backfired a few times and shut off. Started up again and gave it ga it was normal to 3000 rpms then break s up and falls in its face and backfires.
Going riding taking the pro s will try new plugs when I get back to shack.
CustomApexMan
What's your a/f ratio at idle
Yamadog
Just got back put key in started fine did 4 Wot runs at 12#s and ran fine WTF
It knows who you are and it dont like being abused.
allyammies
Did it overload on fuel while it was trailered?
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
Worst luck ever... what are the odds of that?
Yamadog
Pisses me off came back atb6 pm started fine ran 70 miles last night heading to shack 5 miles away shut off at 80 mph almost launched me over the bars then caught but limited rpms and backfire limped back and parked it. It be as flashing low temp warning and temp gauge was going from 39 to 157 did get a code once but only know it was 16?? Then went away would hardly run to put on trailer
I've just about had it with this sled
tapex_07
- Feb 15, 2009
The electrical gremlin!! One of the worst to diagnose.... good luck, I hope you find it without to much trouble.
Groomer08
you dont by chance have a lithium battery in that sled do you?
heard the viper HATES the earth X.
makes me scared to try it!
worked fine in my nytro!
Groomer08
shorted/pinched wire, got agrevated on the trailer ride, or TORS malfuntion? possible throttle cable slack issue??
had a nytro in the fleet start acting up this season, tors on low speed full lock right turns only. have to kill, straighten bars, restart.
i blame the guy who put the riser on routed cable wrong side of steering post.
Zampinator
Groomer is dead on! Check your TORS, if not a short, but I'm betting TORS, I've had it happen on older sledsshorted/pinched wire, got agrevated on the trailer ride, or TORS malfuntion? possible throttle cable slack issue??
Yamadog
Stock battery, not tors why would the engine temp flash from 39 to 170 and red low temp light flash.
Sled is not hot, water level is good Afr was 10.5 at wot when it was running. I blend 110 octane with gas I brought from home. It would not run coming off the trailer then left it sit all day started it at 5 and rode till 11 then dumped on me
It hates you...
wot-75
Do you have links to posts claiming this? Just curious. I have a liFePO4 battery in my sled but it seems to run fine,
Yamadog how's the snow in Hurley?
