wesj
the ski bolt looks much more effective as it throws it on the front of the track rather then twards the rear of the track.
Cherry08
Does that do any damage to the ski? It definatley throws snow
pretty cool might have to get a set
MidwestMike
- Sep 14, 2012
- Oak Lawn, IL Ride in SW Michigan
- Vector
That's a good point with the stud and bolt idea, you really have to work out something for reverse.
I wasn't even thinking about that.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Maybe in reverse, the Ski-z scratchers just spin around backwards and back the other way when going forward again if that screw know isn't tight.
With any of these, it's the performance of glare ice that is the question.
Paraclete
correct they spin around so you can backup without taking them off.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Seeing how they are mounted to the bottom of the ski. How do they work when loading them on a trailer?
Paraclete
they recommend taking he off before trailering. I take them off and mount them on top of the ski so they don't take up space in my luggage.
gsxr
- Feb 24, 2006
- BRACEBRIDGE , ONTARIO
- 2023 SRX
stud
If if the upside down stud you are asking about , it is in the air in the trailer , touches nothing ! Only touches when the ski is deeper in the snow !
engineman
- Feb 19, 2013
- Between Hastings & Redwing MN
- 2009 Apex LTX, 2010 Vector LTX GT, 1996 Indy 500 SKS
Re: stud
Any issues backing up? Does the ski rock lowering the rear and causing a problem or does the ski itself prevent excessive rock thus preventing any reverse issues?
If no reverse issues this could be the cheapest fix for cooling/slide lube IMHO....
Thanks!
Steve
gsxr said:If if the upside down stud you are asking about , it is in the air in the trailer , touches nothing ! Only touches when the ski is deeper in the snow !
Thanks!
Steve
gsxr
- Feb 24, 2006
- 2023 SRX
no issues using for 5 years +
The odd trailer may have a piece of angle iron to hook , just watch as you go over it ! The ski will flex , stud is tough , use a regular stud washer on the bottom , works great !
Puts up a nice spray 24/7
Paraclete
snobill
- Nov 4, 2012
- Wisconsin Rapids , WI
- 2012 apex xtx
What he said .
engineman
- Feb 19, 2013
gsxr said:no issues using for 5 years +
Cool! Thank you sir!!!
Steve
Cherry08
Any pics of the stud installed?
- 146K
- 46K
