hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I have a few sets of new black curve kits with 4" carbidesin stock List is 370. Will do $340 on them. You also don't need a curve mounting kit. I provide hardware and instructions on how to trim stock ski rubber to fit. Saves you an additional $40.
Black7
- Mar 23, 2013
- Michigan
- 2015 SR Viper X-TX
2016 SR Viper S-TX 137 DX
Are these the Curves XS series? I may be interested in two sets. I thought that I had my XTX in a pretty good spot until I road it yesterday. Got a lot of darting on hard pack, but was pretty decent on the groomed trail. Tried backing into my shop yesterday, I had so much ski pressure that the track just spinned on the concrete and the sled did not move. I'm going to let my limiters back out a hole and see if that helps.I have a few sets of new black curve kits with 4" carbidesin stock List is 370. Will do $340 on them. You also don't need a curve mounting kit. I provide hardware and instructions on how to trim stock ski rubber to fit. Saves you an additional $40.
rbell14
Received my new skis today. Boy do they look sweet and the dooly slim jims offer some serious bite. I can see why these perform so well.
Super1c, on install does the steep angle of the rubber for the ski go towards the back of the ski?
super1c
Moderator
- Apr 10, 2010
- Freeland - Otsego lake, MI
- 22 sidewinder LTX-LE
super1c
Moderator
- Apr 10, 2010
I set toe out to 3/8 as discussed in other posts
chuckpp
- Mar 27, 2013
- Belmont N.H
- 2016 Yamaha srviper ltx dx
Where did you get them? how much?Received my new skis today. Boy do they look sweet and the dooly slim jims offer some serious bit. I can see why these perform so well.
chuckpp
- Mar 27, 2013
- Belmont N.H
How did you loosen the inside nuts is there something you must take off to get to adjust the inside?I set toe out to 3/8 as discussed in other posts
super1c
Moderator
- Apr 10, 2010
I may get roasted cause proper way is to loosen inside after removing boot. But being impatient and wanting to try set up I only adjusted from outside bolt after removing from steering knuckle. It doesn't take but a turn to get your toe out right. I wasn't even very precise. It handled so well I just left it as is. I don't think any harm was done or will have any I'll effects.How did you loosen the inside nuts is there something you must take off to get to adjust the inside?
tony lawhead
I put curve mnt ski's on mine best money I have ever spent on a sledStock Ltx-dx, no studs, noticing a push then grab sometimes when cornering at moderate speeds. What carbide would be a solid improvement over stock? Brand and size? Inside and outside. Love this sled other than this minor issue and would rather not replace the skis just yet. Thanks!!
rbell14
i purchased from curve industries direct. Check site for price but if I recall correctly it was $400+ with mounting hardware.
matthew eurich
- Jan 26, 2017
- Freeland/Gaylord MI
- 2011 Venture, 2000 SX700, 2016 SRViper RTX-DX
super1c
Moderator
- Apr 10, 2010
Hoping for some snow for sure. Nice sled! That's the color I wanted but they didn't offer it in the LE model.
chuckpp
- Mar 27, 2013
- Belmont N.H
I have the exact same sled got it about a month ago ,love it but haven't done the curves yet .View attachment 125958 I'm very thankful to all of you that contribute to this forum. I just purchased a SRViper Monday and will pick it up Saturday....very excited! I've been looking for a while and found an offer on a new one I couldn't pass up. I already order curve XS skis for it because of this info. A number off you have helped me out on the 2 stroke forum in the past and I appreciate your insight now. Looking forward to a nice riding Viper without all the pain of messing with the tuners. Let's all hope for an larger than expected snow storm for Northern Michigan so the trails will be good this weekend! (maybe just wishful thinking)
Sent from my Pixel using Tapatalk
parepadarappa
- Mar 27, 2008
- Sault Ste. Marie MI
- 2016 SR Viper X-TX, 2002 SX-r 600
If you don't want to spring for the curves, I've found that 6" shapers on the inside and the stock 2" carbides on the outside made a HUGE difference in the handling. It's almost tolerable to ride now.I have the exact same sled got it about a month ago ,love it but haven't done the curves yet .
rbell14
Logged 110 miles on my new curve skis, very happy with them. Sled goes where you want it to go, cornering is very good. Glad I purchased them, way better than my stock ski.
- 6K
- 40K
