shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Is this for a stock baseline setup? Does swapping to a 1.6" Ice Cobra, or any of the mods in my sig make any difference?
I can't see your signature in Tapatalk. Follow what ninja said.
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
2016 Vector LE For my Bride
2007 Phazer GT, 136" Stretch.
2002 SXR600 (still own)
1997 SX600 (sold)
1997 XT500 (sold)
2013 Can-Am Maverick 1000XRS
Sled is almost identical to mine. Set-up I gave you is the same as mine other than I run the 1/4" buried below the 3/4", and I like a 46/40 helix.I can't see your signature in Tapatalk. Follow what ninja said.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
- 14 Viper LTX, 10 Turbo Phazer MTX, 08 Phazer, 88 SnoScoot
Damn, it happened again. Both typing at the same time.
lol. Yes, you both seem in agreement about the tip at least!
Tip: Steel w/ thin washer.
Mid: Aluminum (washer?)
Hell: 3/4 (possibly +1/4)
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Great! Thanks! Wait, whats a 46/40 helix?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
That is exactly where I started but found I had to load the heel with 1/4 + 3/4 and mid with 1 thin washer to keep it off rev limiter at launch. Only time I hit it now is when the track breaks loose and it's usually only one or two quick taps. At WOT I am 8950.lol. Yes, you both seem in agreement about the tip at least!
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
Helix in the secondary. I run a Multi angle 46/40 (46 degrees first half and 40 degrees second half) helps to control launch by loading the engine more in the bottom, and speeds backshift. Don't worry about the helix. It personal preference and the stock helix will work just fine and was a little faster top end for me.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
So should I just put the 1/4 in the heel now? The only testing I will be able to do is out on the lake across the street, which now has zero snow on it. Now sure how good of a baseline testing grounds that is, and I'd rather not make all my buddies site around while I tweak my clutch kit on our next trip!
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
You can and it shouldn't hurt. If your RPMs end up a little low, that's okay because these engines have a flat torque curve. A little too much weight is better than not enough which results in over rev. As long as you end up 8600 - 8900 you'll be okay. just don't want to be bouncing above 8950 as you'll get into the rev limiter. You'll need to ride on snow a bit to have a better feel for real world rpm since we don't ride ice all the time.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Thank you so much man!
I didnt think anyone was going to respond tonight, and I was bummed.
Last question and I'll stop buggin ya: I thought the consensus was 6/1 on secondary? Do I still start with 3/3 even on a stock helix?
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
I run at 6-1 I think. 3-3 will give you more speed and a touch lower RPM, but backshift will be a touch slower than 6-1. Again, this becomes preference on how you like the sled to feel.Thank you so much man!
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
You can always try both wraps. Changing that only takes a few minutes.
DigitalFusion
- Jan 19, 2011
- Chisago City, MN
Tight and twisties through the woods is my drug of choice. Not too concerned about top speed
SnoNinja
aka "Plan B"
- Feb 18, 2015
- Gaylord, Michigan
- 2015 Viper LTX-LE
1997 SX600 (sold)
1997 XT500 (sold)
6-1Tight and twisties through the woods is my drug of choice. Not too concerned about top speed
shagman
Vendor
- Feb 18, 2014
I'm almost always watching.
mattchew_3
- Dec 28, 2014
- SR Viper
I finally have the kit installed. With the weather tested time has not come yet. The little bit it did do was in a virgin field. Seemed to go to 9050 off the line spinning and right around 8900 at wot. Hopefully I can get on some packed snow this week. Should I be at a 6-1 or 3-3 wrap. Sled is a 129 standard model no mods.
Sent from my SM-G920R6 using Tapatalk
