mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
kinger
heath@mpi said:kinger said:I am salvating after seeing my dyno from Ulmer and just waiting on my first long hard pull! This year is going to be the best ever....unless I blow it up.
WHat did it make
243 hp on 91 octane. He thinks he get get a little more before he is done. This is awesome!!!!
KnappAttack said:As you know Dan, some of the best stuff just has to be hand built!
It also unplugs for easy removal, notice the plug in sitting right in front? Its a four wire trailer pigtail.
...ABSOLUTELY
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
kinger said:heath@mpi said:kinger said:I am salvating after seeing my dyno from Ulmer and just waiting on my first long hard pull! This year is going to be the best ever....unless I blow it up.
WHat did it make
Kinger that is rockin buddy!......im sooo damn excited about my SC now!....
I hope to be in the 240 range myself!...awesome stuff from Allen!
I think my setup is damn near same as yours!
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Kinger.....some questions...
-what RPMS were you running for the 243HP?
-how much BOOST did your gauge show at those RPMS?
-what pulley combo?
-.062 headshim with split gaskets above & below?
I want to get some of this info figured out,it will help me alot to get my clutching dialed in.
thanks!
Dan
-what pulley combo?
thanks!
Dan
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
10,800-11,000
10 psi
-what pulley combo?
26 on engine crankshaft 24 on supercharger jackshaft
Cometic .060" thick head gasket, no shim or stock gaskets used
10,800-11,000
10 psi
-what pulley combo?
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
thanks alot Allen!....very awesome numbers you got there!!!
Dan
Dan
