i have had good luck with hjc cl-12 and cl-15 with heated sheilds. -40c out and my glasses do not fog up in the cl-15/csair. had probelm with the cl12 but sold that one after i bought cl15. going to try a cl max modular this winter.
Mooseman
- Nov 3, 2009
- Greely, Ontario
- '07 Venture MP (gone)
'07 Phazer FX (gone)
'09 Phazer GT (gone)
'10 Nytro FX (son's)
- Greely, ON Canada
Irv said:You had to do all that wiring with the Kimpex adaptor?
I thought there was something similar to your pic that you just plugged into your accessory outlet?
No, I actually drilled a hole and permanently mounted it right next to the accessory outlet. What you're thinking of is the adapter available from Yamaha:
http://yamaha-motor.ca/accessories/accessory_details.php?item=1624&group=S&model=1991
Was not going to pay $43.95 for that so I made my own. Then I switched to the permanent plug.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
Mooseman said:Irv said:You had to do all that wiring with the Kimpex adaptor?
Thanks for the info and link, that "IS" one pricey adaptor but I do have a feeling it would be (or should be) a lot better than an after market one?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
I love my E shields, have both the HJC CL12 over ten years old works great and a new to me HJC CL 15 and love that as well.
Before you spend money or time on a plug try this, I love it. I run the female end of the cable out through the steering post opening, secure it with black zip tie with a couple of inches of play. Then when I ride with the E shield I run that cord either in my jacket or between the double zipper layers so the cord comes out at the bottom of your zipper. Now the cord is never in your way, not flopping around, and if you get off or fall off the cord just unplugs and no harm no foul.
Every year I really want to buy BVS2 but then I can't see why when my HJC heat shields work so well.
Yamadoo
Yamadoo
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yamahas said:I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
The only alternative to the adaptor is to hard wire it in, which, being as I am electrically inept, might be a difficult task for me?
My XLT came equiped with one but I never used it. I believe it is always on or always has power when you plug your shield in?
Is that how I would wire up my Vector?
Any info/links/pics of wiring one up available?
- Nov 1, 2009
- 2009 Phazer RTX
Irv said:yamahas said:I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
I hooked mine up right at the battery andthe female end come out at the handle bars. And never had an issue.
I will be installing a fuse this year though just to be on the afe side just not sure what fuse to use.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yamadoo said:I love my E shields, have both the HJC CL12 over ten years old works great and a new to me HJC CL 15 and love that as well.
Yamadoo
That's a good idea but I didn't think the cord would be long enough to do this?
Are most/all cords the same length?
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yamahas said:Irv said:yamahas said:I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
I assume the female end and wire your referring to doesn't come with the e-shield or does it?
Where do I purchase those
Started using an electric one a few years ago and will never go back. They work great.
- Nov 1, 2009
- 2009 Phazer RTX
Irv said:yamahas said:Irv said:yamahas said:I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
The female end wire with the battery terminals on the other end comes with the e-shield in all of my past experiences. It should also come with the 2 male end that plugs into your visor then also into the female end that would come out of sled at the handle bars.
Irv
- Mar 23, 2005
- ONT. Canada
1995 XLT SP (Son's)
yamahas said:Irv said:yamahas said:Irv said:yamahas said:I would stay away from the lighter plug adapter. I had one (not the yamaha one) and it would come out with the vibrations and bumbs on the trail.
Think I am going to get that HJC Surge helmet with the electric shield, it fits me great and feels real comfortable when I try it on.
I also like the fact it is Snell approved.
Appreciate all the help guy's
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
I have 08 apex i bought the new swith that yamaha has on the handle bar mad a pug so i could plug in the accessories plug I got the ends from a yamaha outboad dealer and spiled it in sorry for spelling
ScottyD
i have had an electric shield since 97, wouldnt go without 1, i attached my cord at the battery booster cable ends and then ran it up thru the riser to the left side of the pad, no problems
jat59
I too did not want to pay the big $$$ for the adapter. I checked with a BRP dealer and got my adapter there which also came with all the wire/cord you need. (Just another option)
As for wearing glasses, I too wear glasses. I use a BPR modular II helmet with an E-shield. I have not had any problems fogging, but one day it was really cold and raining/drizzling. It did freeze up at one pointwhen we stopped for a bit but I scraped it off the one time and had no problems after that.
