03 Rx-1 extension
snowfreek20
Traverse City, MI
ok i know this topic has come up in the past, but I need to know what my options are. I have an 03 limited 121" track, I would like to have 144" can I purchase the kit from mountain performance? or do I have to find a 144" skid? I was looking at the cross country kit from MPI with the lowering approch angle. Then if I am able to run the MPI kit, can I run a 1.35" cobra track with 9T Extroverts? Thanks a ton
That sounds like a 4" relocation + 7.5" extensions. If you need the suspension to actually work, don't do it. Since the track doesn't follow the same angles as the suspension arms, it will tend to tighten up a LOT as the suspension compresses. It will cut you down to maybe 3" of usable travel IF you keep the track very loose.
shorter stretches work better, i.e. 136"
I suggest that if you want to go to 144", that you either get a proper 144" skid, or get a skid that is compatible with relocation/extension. The proaction is definitely NOT.
I run 121-144 extensions in my turbo rx-1. No probs what so ever & I bet I got more hp then you.
That is the kit I put into my 03 ton.
VERY nice results. Only down side is I did not go longer..
Well there is always next season
yes it is a proaction suspension. Let me as everyone this, If I was able to get ahold of a fast M-10, would that be better to relocate and stretch? If I have to i'll go 136, but I would like to go 144! Thanks for all the opinions and suggestions!
Would it be ok to go from 121-144 without relocating the monoshock skid and just using extensions?
Would it reduce my travel and screw up the ride?
Thanks this stiff is new to me.
I'm interested in this as well, i would like a 144 with tip up rails.
