03 RX1 Bender stage 2 turbo - ASPHALT and now the questions
Went out today and pulled the carbs. Blew carb cleaner and ran a small wire thru each of the jets to be sure nothing was gummed up. Air screws were at 2, pilots, mains etc were stock. Reassembled it and ran it for a sec then opened up a bit on the grass to see how it was responding (that and to piss off the neighbour). It seems to run a little cleaner....this weekend at the track will tell the story. 3 days or racing this weekend. If its really running well it will be nice to see how much quicker its going....now I can only stop myself from running C12 and 10+ lbs of boost :Rockon:
IF you haven't already checked the waste gate activator, make sure there is a slight tension when connecting the rod to the waste gate. About 1 turn of tension instead of the rod just fitting.
Mine came from Bender without any tension, and it really bogged on hole shot.
Got a Prologger Boost from MPI and got it installed. Mid and WO throttle is a bit fat so Im working on that. I cant, so far, get it above 4.5lbs of boost even when I set it to 6.5lbs. I even added 1lb of boost to the gain setting but that didnt make a difference. Im am going to attempt to set it to 10lbs of boost and see if it increases at all.
