Hey guys, new to the forum. Ive done some research but no luck when it comes to a stock RX1 with only the primary and secondary springs replaced...
My 03 RX1 with reverse is Bone stock, I've noticed that being a carb setup it has quite a lag when you go to pin it, like under revs then takes off. Now Im told that is due to the clutching and if I change the primary spring it will get rid of the under rev lag. does anyone have any experience with the Rx1 and its clutching setup? I do not want to lose any top end, and I dont really want to do a clutch kit because of stories ive heard. I like it to be reliable and still pull good mph up top, I go on long trips with it, cant afford to break down. the sled tops at 9800rpm and will climb to 10,200 rpm, but the odd time is a lil lower, guessing due to the conditions. is there anyway I can get rid of the under rev when you go to pin it and still have a reliable trouble free sled, just by changing the primary and secondary springs?
any info would be greatly appreciated, thanks guys!
