hot331
I now have 540kms on the machine and it seemed to have no power. It would only rev to 7000 out of the hole and slowly climb to 9000 after a long time all my buddys hit 10200 right away I changed my plugs they looked lean very light tan then I noticed that the air box was not secured could this be the problem....Thank-you
Skydog
Man some thing is way off? Sled stock?? Did you try a new belt?
- Sauk Prairie, WI
- www.ty4stroke.com
hot331 said:I now have 540kms on the machine and it seemed to have no power. It would only rev to 7000 out of the hole and slowly climb to 9000 after a long time all my buddys hit 10200 right away I changed my plugs they looked lean very light tan then I noticed that the air box was not secured could this be the problem....Thank-you
If the air box was not sealed around your carbs, thats your problem...BBY
hot331
I had put on a roller secondary just waiting to install heavy hitters I was hoping that it wasnt the mismatch clutching and that it was the air box..
RX-1 Touring Freak
sounds like air box tighten and recheck
MOTOWN SPEEDFREEK
If air box is loose thate your problem,if you have K&Ns youhave to have the 2 vent tubes facing to the rear of sled.
