gmcman2012
well after cleaning the crabs the sled ran great we put 350 mi's this past weekend and sled ran good but i noticed that after the first 30 to 50 mi's when we started the sled it would rev to about 2000 rpm or so and after a few sec's it would return to around 1100 rpm's is this normal with these sleds or is something wrong. thanks for any help.
sounds like the problem. whne cold they do this untill they are warmed up but all the time means they need to be cleaned.jdp1under
- Oct 19, 2009
- CT, NO SNOWVILLE
- 2010 RS VECTOR GT LTX STOCK FOR NOW!
x2 clean the carbs again it sounds like piolts are plugged it can only take one to throw it out of wack! Make sure you run something thru them so there clean! good luck
apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
pilots in the carbs ...very tricky little sucks ...x3
