newrx1guy
Are you runing the stock weights with the 14.5mm rollers?What is the advantage of the 14.5mm rollers?Thanks
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
How do you like the TPI valves Im thinking of doing a set on my RX-1 and 160 mains and red holtz
They work very well without sacrificing fuel mileage, I was getting the same as the 05 RX-1, The Mach Z was getting almost as good, the MXZ 700 and the Rev 800 where drinking it up
Bob Miller
- Apr 19, 2003
- New Milford CT
newrx1guy said:Are you runing the stock weights with the 14.5mm rollers?What is the advantage of the 14.5mm rollers?Thanks
BlackJohn recommended them for better accelleration and I believe they work well
newrx1guy
Are you running the stock weights? Thanks
Bob Miller
- Apr 19, 2003
- New Milford CT
yamahajunkie
bob did you end up moving the weight from tip to heel?
black john
arm,s
yes all that with stk arms and rivets. amazzing eh.
Bob Miller
- Apr 19, 2003
- New Milford CT
yamahajunkie said:bob did you end up moving the weight from tip to heel?
No the weights are stock set up
Black 1000
Ok so you have been setting up the stock set up and are getting great results. Is this set up trailable or race or both? Congradulations on your findings by the way. I hope to be as successful messing around with mine.
Bob Miller
- Apr 19, 2003
- New Milford CT
Black 1000 said:Ok so you have been setting up the stock set up and are getting great results. Is this set up trailable or race or both? Congradulations on your findings by the way. I hope to be as successful messing around with mine.
This set up is good for both
And thanks to blackjohn for giving me the info Similar threads
