05 rx1 secondary
dingus
MN
i am going to be taking the secondary apart for the first time on the rx-1. all my clutching mods were done to it before i bought it. just looking for some tips and tricks as i will be changing out the outside sheave. i tried to do a search but cant find any dis-assembly help. thanks
also... who has made there own spring compression tool and do you have any pics of what you used and how you made it?
Spring compression tool? What for? Grab a couple of C-clamps to hold the sheaves together, remove the three nuts holding the helix in place, GRAB the helix with your hands (you can use leather gloves to hold it if you're not comfortable twisting against the spring), turn the helix CLOCKWISE to remove sideways tension, and pull off. Before you completely remove everything, make note of which holes the spring sits in. Assembly is the reverse.
Oh yeah... one thing to note: It is MUCH easier to work on the secondary clutch while it is still bolted onto the jackshaft with the e-brake set.
Once the helix is off, remove the bolt holding the clutch onto the jackshaft and remove.
