JODY
I have an 06 Apex GT and in the process of installing the 136 extension kit. Could someone tell me the best setup for the clutching and gearing. My machine is stock except for the track extension I was told to run the 23 tooth gear so I ordered it but should i do something about the clutching like a new spring in the secondary with different tension. Any help would be greatly apprciated
Thanks Jody I'm installing a 136 x 15 x 1.5" ripsaw if this changes things for the clutching suggestions
06RTXTASY
I was told by many on here to go with the 23 top gear and the White secondary spring which is the same as the attack with a 3-3 twist.
