northbaydave
- Dec 6, 2011
I have an 06 Apex GT that I have owned for 4 years. I've never had any problems until I threw a stud and punctured the front heat exchanger. I have a buddy who owns a welding shop so we fixed the leak right away. Ever since then I can't keep the coolant in it? It gets up to temp, fills the overflow then spills on the ground. I thought vapour lock so I raised the nose almost vertical while up to temprature 3 times and its still doing the same thing? Any solutions?
There is a bleed screw at the back of the sled.
northbaydave
- Dec 6, 2011
Oh, so there is!!! I guess i'll just run it and bleed off the air. Or is there a special technique?
trailhed1
Someone for sure will know the procedure to bleed it, i believe you need to elevate the rear of the sled to bleed it properly.
I had a friend with the same issue after a weld repair to the front exchanger. Turns out the weld actually stopped coolant circulation. Had to change it out.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
trailhed1 said:Someone for sure will know the procedure to bleed it, i believe you need to elevate the rear of the sled to bleed it properly.
X2
heat exchange
Tells you how in the manual.When prompted pick slow download
http://www.4shared.com/document/KcyWZe1 ... anual.html
