I have 06 gt apex .when i am in moguls or rough terrian I here alot banging or clunking under sled.Checked shock when i changed to the big boy spring .it seemed fine. I adusted track to 1 3/16 at 21 pounds nothing looks broke not sure what it is. thanks Paul
Its the limiter strap pulling tight. Not a problem. BTW, you can run a looser track as long as you don't launch from dirt and grass. You'll get better hyfax wear, top end and fuel economy. I run 3/4 inch freeplay no weight, no problems.
its the transfer rod making the clunking , pull it apart and install rubber
o rings instead of the plastic washers that are in there, was a post on this
a while ago with picts, it stops the clunking!!
