TieStrap
- Jan 4, 2015
- '06 Apex GT
I have a 2006 Apex GT. My Ohlins shock wouldnt come up on the speedo last year. I had it fully re built with a new solenoid. It is installed with power going to it. I still can not get it to come up on the Speedo.
vodoo child
- Oct 29, 2005
- Palmerton Pa.
- 2018 Sidewinder LTX/LE 50th
I would check for a broken wire first. Lot of ice builds up on top of that shock in the tunnel.
TieStrap
- Jan 4, 2015
- '06 Apex GT
I already made sure the wire was not broken.
You need to push mode on dash if you havent done that already.
TieStrap
- Jan 4, 2015
- '06 Apex GT
I did that already.
chris189
- Nov 27, 2011
- Hanover Ontario
- 2007 Apex GT, 1980 Enticer 340
Something must not be connected. I did a test on mine just the other day. It is true that if the connection is not there then it will not give you the picture of the shock and the ability to adjust it. I tested this by unplugging and plugging back in. Maybe the harness up inside the sled has rubbed through?
Its a bad gauge, harness or solenoid. There is always a chance its the CDI but the others are more common failures.
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
I have a 06 apex gt how do you get to the shock setting on ur speedo I did not know u could do this
Click on the right hand warmer control, then click on the mode button and you should see the hand warmer area on the gauge turn into a shock.I have a 06 apex gt how do you get to the shock setting on ur speedo I did not know u could do this
gytrapex
- Oct 5, 2014
- 06 yamhah apex gt
When u click on the warmer control do u push up or down on it and do u hold the warmer control as the same time u push the mode button and when the shock shows up can u make the shock hard or saft I never new I could do this so idk how to do it yet
Go here and you should be able to read how to adjust it.
http://www.manualslib.com/manual/660035/Yamaha-Rx10gtl.html?page=26#manual
