Mr WFO
Anybody have this problem The rear skid clunks bad over sharp bumps gets less noisy if mono spring is adjusted tighter I know its the adjustable link makeing the noise
. What can I do?
. What can I do?
Turk
Tech Advisor
Search clunk or suspension clunk. 2 years of posts on this subject.
Honk
people were installing an o-ring inside the transfer rod. it will quite it down some.
That's right. sound comes from transfer rod banging to dead end.
Will this o-ring last in there more than one trip?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Nothing you can do. Its the transfer rod. Ride it and ignore it. The faster you go, the less you will hear it.
Mr WFO
thanx for the info all of it makes sense I hate the noise I will try a soft rubber stop inside transfer rod cheers
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
I found under 15 or so mph makes a clunk on the sharp edged stuff. Solution is go faster. I was riding with pokey Machz guy, but on my own, I never noticed it!
Charged RTX
WFO has a good idea. Has anyone tried rubber inside. I have some 1/4 inch rubber that may work good!
